C-clip removal questions
Old 10-15-2010, 09:22 PM
trik396's Avatar
Default C-clip removal questions
I've done this before many moons ago on a 12 bolt in my chevelle. Now with the 10 bolt I am having difficulties....
Is there any other way to get the axle to move inward other than beating the end of it with a hammer and piece of wood??? It seems that it's really tight and no way for clearance to remove that dang little C clip...
Any help is appreciated.
Old 10-15-2010, 10:43 PM
gofastwclass's Avatar
If you have a 4 channel rear you will have TCS sensors at each wheel. The sensors need to be removed from the backing plate with a 10mm socket before the axle will slide inward enough to remove the C clip.
Old 10-15-2010, 10:46 PM
trik396's Avatar
3 channel here and I got em out. Thanks for the reply.
Love your sig, btw...
Quick Reply: C-clip removal questions
