rear differential noise
Old 10-27-2010, 02:19 AM
HoLLo's Avatar
Oops. I'm thinking of the transmission, it needs 4 quarts. TWO quarts of gear fluid for the rear-end. It's the only thing I use Royal Purple in. Definitely get a new gasket, hell it's only a couple bucks.
Definitely pick you up a Haynes/Chilton book. They have everything on basic maintenance.
This site here will walk you through it. http://www.bfranker.badz28.com/fbody/lubeoil.htm You can use the two quarts and diff additive, or just two quarts with additive included like Royal Purple. Your choice.
Old 10-30-2010, 10:02 AM
BirdsSince16's Avatar
Hope things went well if you've tried it yet. Let us know if not.
Old 12-05-2016, 02:54 PM
Weeks14's Avatar
Default 2001 Trans Am Stock
I am also having the same issue as the guy above but I get a clicking like noise on my left side and sometimes at low speeds from when I first take off. Any ideals?
Quick Reply: rear differential noise
