broken Moser 12-bolt....
My drivers side bearing on my spool exploded in my Moser 12-bolt. Has anyone else had a problem with this? Does anyone know if these bearings are exclusive to Moser or can I get them anywhere else local maybe? Thanks for any help.
Jeffrey
Jeffrey
I had an axle bearing go out in my 9" once. Tried everywhere looking for the exact bearing that Moser had sent me. I ended up trying local shops, and Autozone had it, believe it or not. They carry the whole line of Timken bearings.
my buddie couldn't find them anywhere locally when he had one go out. don't know if he tried autozone or not. he ended up having to buy them from moser, and got charged a butt load
The carrier bearings are not exclusive to Moser. You should be able to see the bearing part number etched onto the bearings bottom side. Give that number to any local parts place and they should be able to get it for you.
Auto Zone has an *** load of bearings for everything. My dad once found a gob of 70's model Ford tractor bearings that would have normally been only available at a tractor place.
