Rebuilding Rear end, what do i need?
Old 06-07-2011, 01:01 PM
bogfobmal's Avatar
Default Rebuilding Rear end, what do i need?
So i recently popped my rear end, and instead of fixing whatevers broken, i'v decided just go tear it all down, and rebuild the whole thing. So for a complete rebuild, what will i need?
Old 06-07-2011, 01:17 PM
Troy5061's Avatar
1. Ratech Complete/Deluxe install kit from WS6 Store, its about $108. It comes with everything you need as far as shims, bearings, gaskets, and seals go.
2. Ratech solid pinion spacer, not a must but highly recommended.
3. 2-3 qts of gear lube.
4. New ring and pinion gear for the ratio you want. I would suggest AAM gears. 3.73s if auto and 4.10s if manual. You will need to reprogram your PCM if you change ratios from stock though.
5. Not needed but I would get either a TA or Mac girdle cover, they are cheap and anyhelp for the 7.5" is nice.
Providing your axles and posi unit are still good that should be it.
Old 06-07-2011, 02:13 PM
djfury05's Avatar
Weld the axle tubes to the housing as well in addition to the above listed.. or just save your money and get a rear end worth getting because the 10 bolt is worthless and it will probably break again.
Quick Reply: Rebuilding Rear end, what do i need?
