emergency brake shoe removal
Old 06-23-2011, 09:33 PM
97ss497's Avatar
Default emergency brake shoe removal
I've got the 10 bolt out and the MWC 9" ready to install. How does the emergency brake shoe come off?? There's a bolt and plate up top behind the axle flange but it looks impossible to get to. Anybody done this recently? I don't have to remove the axles do I?
Old 06-24-2011, 05:10 AM
97ss497's Avatar
Anybody?
Old 06-24-2011, 08:48 AM
Coal Mining Director
onfire's Avatar
You have to remove the 4 nuts with an offset wrench, then pull the axles out to get the backing plates off. It is very easy.
Old 06-24-2011, 11:51 AM
97ss497's Avatar
I don't want to remove the backing plates I want to remove the e-brake shoe.
Old 06-24-2011, 03:42 PM
97ss497's Avatar
anybody? I'd like to remove them tonight....
Old 06-24-2011, 11:36 PM
SS SLP2's Avatar
just slide the shoe up and it will dis-enguage the clip then roll the shoe side ways and it WILL roll off the axle ( you may use a off-set screw driver to remove the clip if you wish to remove it )
Johnny
Old 06-25-2011, 10:58 AM
97ss497's Avatar
All I had to do was pull up on the shoe and it came off the clip. I then used a screwdriver to pry it off the axle.
To put it on the 9" I had to remove 2 of the backing plate nuts and screws to get the shoe installed.
Time to install the 9"!
Quick Reply: emergency brake shoe removal
