bearings or axle
bearings or axle
well my 10 bolt start making a loud screeching noise the other day. and now its grinding and the pass rear wheel seems bound up. the noise is from the outside of the axle. not in the center section. could it be the axle bearings? wheel bearings? or is the axle damaged?
cant tell from your discription.. but id say wheel bearing,,just a wild guess.. but no matter what you need to drop the diff cover and see whats going on,, that should tell you whats going on... i thought mine was coming from the outside too.. but it was the pinion bearing went bad.. look for leaks anywhere fist,, and then take the diff cover off... and hope for no chunks falling out when you open it up...lol good luck
