Driveshaft for TH400 to 10 bolt???
LS1Tech Premium Sponsor
We can get you into many different drive shafts. How ever it is best you take the proper measurements that way you get the drive shaft you need for your particular application.
You want to have the vehicle at ride height and measure from the seal of the transmission tail shaft to the center of the u-joint on the rear end.
You will be after the "X" measurement.
