leaky 12 bolt
Old 09-19-2011, 02:40 PM
Blown02Camaro's Avatar
Default leaky 12 bolt
Hey guys I got a 12 bolt put in about 5 months ago form a local shop. About 2 months ago I had found a leak on the diff cover which was an easy fix. Now over the weekend I was installing some parts parts on the back of the car and noticed grease on the back driver wheel. Upon further checking it looks like it is coming out of the axle shaft housing and I have no idea why,and it is also leaking out of the pinion seal. Do yall have any idea why these places are leaking and what is the best way to fix them.
Old 09-19-2011, 02:58 PM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
LS1Tech 20 Year Member
Do you have it filled with gear lube to the bottom of the fill hole, which takes about three quarts of gear lube? I asked this because some people fill it up to the top of the axle tubes through the vent hole on the driver side axle tube, which puts way too much lube in it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 09-19-2011, 03:05 PM
I filled it until it started to run out of the hole on the side of the diff.
Old 09-20-2011, 10:43 AM
LS1Tech Sponsor
That's good, you have it filled to the correct height.
You can pick up new seals at your local Napa, ask for the parts to a 1975 Ford pick-up 9". Bob
__________________
