help me pick gears for new build.
currently i have a 12 bolt with 4.10 gears and a T-56 6-speed. I'm looking at putting a th400 trans in it soon and i want to install a spool. should I keep the 4.10 with the auto trans or change the gear ratio while i'm in there?
heres the specs:
3460 race weight.
650hp @ the wheels with t56
this is a nitrous car
prolly shifting around 7,000rpm
28x10.50 hoosier slick
not sure what else is a factor in selecting the correct gear ratio.
should i keep the 4.10?
heres the specs:
3460 race weight.
what info do i need to figure out an exact gear that would be perfect. is there a chart or something that i can use with tire size and what rpm i'd want to cross the traps at or something? say i shift at 7k rpm, when i'm goin thru the traps im sure i could hold it thru at like like 7,200 if i had to.
LS1Tech Sponsor
There are a lot of gear ratio calculators on the internet. The one here might help you out. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
http://www.richmondgear.com/112901.html
LS1Tech Sponsor
Sounds like a good plan. Bob
__________________
