whats the min space between bump stop and tires?
I just installed a moser 9" from bob in the car. While under it, and with the rear hanging, I looked up and noticed the driver tire was just resting against the bump stop. I know that when I load the rear it will move towards the driver side because of the way our phb works. I completely loaded it, and could just barely even get my fingers between the tire and stop, looked over on the pass side and theres just a hair bit more room. Now I am not sure what the clearance was on the 10 bolt, but this seems really close. Car does not have an adj phb, and I havent used the string and washer method to see just how off center the rear is. But what is an acceptable measurement? The rubber just seems awfully close to that sharp bracket. Stock width 9", and I have a set of 15x10 greg welds with a 7.5bs on the rear
