98 camaro rear wheel bering question
friend wants me to help him redo all the berings in his rear. he wants to change his wheel berings. i know on my car we had to use a press to change the berings. do you need any special tools to change the wheel berings on a 98 camaro. its a v6 if it matters
You need something to pull the old bearing out. I use an axle bearing puller from HF. Its one where you use a slide hammer to pull it out. To re-install you can use a bearing installer kit with the different size adapters, or put your old bearing over your new one and hit the old bearing with a hammer.
