need help with pinion shim!
Old 02-19-2012, 07:57 PM
poltergeist 02's Avatar
Default need help with pinion shim!
ok, so my old set of motive gears had a pinion depth marked as 2.292 on the pinion and the shim that was used with that set was a .031
now my new set of gears the pinion is marked 2.303 a total of .011 difference.
my question is do i add or subtract .011 from the .031 shim that was on the pinion of my old set?
Old 02-19-2012, 08:37 PM
FirstYrLS1Z's Avatar
are the pinion gears of the same length( from the face of the pinion to the surface where the shim sits) ? if they're different,you have to take that difference into account too.
that marked dimension is from the centerline of the carrier to the face of the pinion.
Old 02-19-2012, 08:40 PM
the new pinion head is .002 smaller/ shorter
Old 02-19-2012, 08:45 PM
i don't have a pinion depth tool. thats why i'm just trying to get somewhere in the ballpark by using simple math.
Old 02-20-2012, 06:48 PM
anything?
Old 02-20-2012, 07:13 PM
based on the info supplied
the new pinion has to sit .011 further away from carrier centerline than the old pinion sat,.031 - .011 =.020.
since the new pinion gear section is .002 shorter,.020 + .002 = .022.
hope someone else will post in to agree/verify/dis-agree.
Old 02-20-2012, 11:17 PM
speed_demon24's Avatar
Subtract the .011".
Quick Reply: need help with pinion shim!
