3channel to 4 channel
iv looked around and seen were you can change a 4 channel rear to a 3 channel, but has anybody changed the car from a 3 channel to a 4 channel? if you put a 4 channel rear in a 3 channel chassis what would you need to do to change it to a 4 channel? i know a 3 channel has one line that comes back for the abs but could you put a "t" fitting there and run them out to the reluctor rings on the end of the axles?
Originally Posted by ShowNoMercy
Off the top of my head, you will need...
-4 Chan ABS unit
-Remove old rear brake line, replace with two new ones
-4 chan axles with reluctor rings
-ABS wheel sensors and corresponding harness.
The wiring in the new ABS block with new sensors would be a royal pain in the *** IMO.
-4 Chan ABS unit
I thought about doing it once...
