Weird parts in Moser 12 bolt box
I am installing my moser 12 bolt. there are a few parts that I can't make sense of where they go. There are a few 'U' shaped bolts and nuts, as well as these two gold colored rings. They have a rubber gasket in the middle with a spring around the inside of the center. The cross section is below, where the S represents the spring and gasket:
|__S| |S__|
I haven't heard them mentioned in any install guide. what gives???
|__S| |S__|
The "U" shaped bolts and nuts are most likely for your u-joint. The rings are your axle seals, you need to put them in the end of the axle tube. They press in, you can tap them in with a large socket, just make sure they go in flush. The "open" part goes toward the inside (the flush part outside).
Good luck, Shawn
Good luck, Shawn
Good luck, Shawn
Good luck, Shawn
Turns out that yes, the U bolts are for the U-joint. The seals don't fit in there... You can't get the bearing all the way into the axle housing. You have to remove it to get it flush... so I didn't put it in.
Originally Posted by BTL FED
If you didnt put the axle seals in it is going to be leaking fluid from the axle tubes pretty bad.
FYI, I got the axles remounted with the bushings in there... I had to go and get some device to press it in there (I hammered it in with a oversized electrical conduit connector). works good.
