Solid Pinion Spacer Preload possible problem
Old 04-19-2012, 12:40 AM
sledneck687's Avatar
Default Solid Pinion Spacer Preload possible problem
I spent about 1.5 hours trying to figure out this pinion preload with the Ratech solid pinion spacer, and new bearings, and I am either not getting any, or what seems to be too much preload. I am using the park tools inch lb wrench. If I turn the wrench slowly, it reads about 40 on breakaway, then settles to 30-32in lb. If I start turning the wrench faster it reads about 40inlb . Will this be alright to run, or should I mess with it some more and try to lessen the preload? Help would be greatly appreciated!!
Thank You,
Jarett
Old 04-19-2012, 06:07 AM
01ssreda4's Avatar
You want the rolling torque figure. Oiling the bearings helps smooth things out. I typically run pinion bearings between 25-30 even though the recommend is 20-25. So I'd run it at 32.
