HELP axle bearing replacement gone wrong
Old 05-04-2012, 11:03 AM
slvr_ls1's Avatar
Default HELP axle bearing replacement gone wrong
would anyone be kind enough to let me know how to seperate the rear wheel hub from the rear end, im attempting to replace my axle bearings but cannot get the damn wheel hub off. There is no axle nut in the center as ive seen on most other cars and it almost looks like its a press in/out type.
Any help/tips/anything at this point would be seriously appreciated.
Old 05-04-2012, 03:05 PM
joecar's Avatar
There are c-clips on the in-board end of the axles where they spline into the differential side gears.
Old 05-04-2012, 03:58 PM
joecar's Avatar
On each side, the hub and axle is one piece.
Quick Reply: HELP axle bearing replacement gone wrong
