Couple of 12 bolt ????
Originally Posted by 01pewterSS
How do you put the axles in and how do they hold in place???
What weight gear oil do i use??
U joint??
pinion angle???
U joint??
pinion angle???
Ujoint is a NAPA 447x
pinion angle should be set ok if you install it, but if you have drag tires and stuff, then I don't know.
here's a pretty good install manual:
http://www.fbody.com/moser.htm
like I already told ya try 85w140 while breaking it in for a few hundred miles and then switch to 75w90 the rest of the way. Pinion angle at -1 for the street, and -3 degrees for the track....the more negative the angle on the street the quicker you'll wear down your drivetrain.
