Rear end
Old 11-29-2012, 10:59 AM
01_m6ss's Avatar
Default Rear end
I need some help verifying if the rear end on a 02 z28 is the same as an 01 ss. On the ss one if I turn one wheel forward the other one goes the same way. On the z28 they go opposite so I just want to make sure its a posi.
Old 11-29-2012, 12:07 PM
FirstYrLS1Z's Avatar
02 Z28s' and 01 SSs' got posi. The 02 Z28 has a Torsen posi,the 01 SS,which would have started out form the factory with a Torsen posi sounds like it was replaced at SLP with an Auburn posi. Auburn was a SLP option.
Old 11-29-2012, 12:15 PM
01_m6ss's Avatar
So if its a torsen or auburn it should still be posi right. Is there anything I should look for if I open it up.
Old 11-29-2012, 08:24 PM
broken pieces,but on the serious side,Auburns wear out when mileage gets high.
At about 120,000 miles,the Auburn 'cones' on my rear were showing wear that I considered nearing the end of their serviceability,at 170,000 it's still going strong,but I expect to be replacing it soon.
Old 11-29-2012, 08:28 PM
torsen
auburns
Old 11-29-2012, 10:30 PM
01_m6ss's Avatar
They guy I'm getting it from said the camaro it came from only had 56k on it. But I know to check on broken pieces in there. Also is there any way check on wear on the carrier by just turning it with my hand.
Old 11-30-2012, 06:18 AM
turning the carrier by hand will only be rotating the carrier and pinion bearings.
Quick Reply: Rear end
