Rear Wheel hub??
Old 01-26-2013, 02:36 AM
Vi3t's Avatar
Default Rear Wheel hub??
Sorry if this is the wrong section....I am looking to change my rear wheel hubs but can't find any online. Is it not like the front where i can just bolt new ones in or do I only do bearings in the back? Thanks!
Old 01-26-2013, 03:14 AM
4WOFURY's Avatar
I see a firebird in your avatar, so I assume you are referring to an f-body.
F-bodies do not have hubs, as they are a solid axle. To replace the wheel bearing, you must remove the axle from the housing.
Old 01-26-2013, 09:57 AM
Vi3t's Avatar
Yes it's an F Body sorry. Ok thanks!
Quick Reply: Rear Wheel hub??
