MWC 9 w/Wavetrac?
MWC 9 w/Wavetrac?
Does anyone on here have the Watts link MWC 9" setup with a Wavetrac, or Quaife diff??
I am asking because I eventually want that axle with either of those two diffs for handling/road racing/autocross (NOT for drag racing/'highway runs' like most on here, so the standard "just spool it" response is a NO GO!).
Wavetrac...no watts link. Went for the 31 spline version and aluminum center, lightend Yukon 4.11. Drives just like the Zexel unit, has more bias on corner exit though.
MWC with watt's link and wavetrac. I haven't driven it at the limit of its handling capabilities, though it drives like a stock rear in the car and is very grippy in corners. No tire chirp or bouncing associated with a spool type, but it seems like it's always engaged and ready for action.
I have however been able to test it at the strip, and it leaves great and straight and handles a 6.5k clutch dump like a pro. About to have a kit on the car and see how the diff likes leaving on gas out of the hole...
