From 10 bolt to 12 bolt?
Old 04-19-2004, 05:19 PM
LS1SS4ever's Avatar
Question From 10 bolt to 12 bolt?
What parts are needed to convert from bolt 10 to bolt 12?
How much it cost? What advantage I get from bolt 12?
Old 04-19-2004, 11:38 PM
Nakoz's Avatar
You will probly need a new u-joint for starters, depending on what yoke you go with. Its probly best if you get the 1350 yoke. Everything else you will need will be on the list of parts that you get from the manufacter of the rear end, mostly nuts and bolts. A complete moser 12 bolt will cost about 2200-2400 with shipping. If you install it yourself then the install is cheap The advantage of the 12 bolt is that you wont have to worry about breaking it like your stock 10 bolt, and you can put a killer stall in your car, or dump the clutch at 5 grand. It helps with dependability and killer 60fts.
Nakoz
Old 04-21-2004, 04:31 PM
Packy's Avatar
Sway bar mounting kit for 3-3.25 inch axle tubes
