? about stock driveshaft and moser 12 bolt
OK guys I have a moser 12 bolt and stock drive shaft. I have the 1310 yoke, if I am not mistaken dont I have to buy a new part so that the stock driveshaft and the 1310 yoke will mate up? If so anybody know a part number or what this part is actually called? TIA for all of your help.
Stock LS1 F bodies use a 3R saginaw joint, if in fact the 1310 on the moser is a true 1310 the stock U-joint wont fit.
If thats the case you need a 3R/1310 conversion joint, precision # 350 or 372 I believe, have someone with a current catalog double check those numbers.
Its pretty common for people to call the stock u-joints in these 1310 so maybe the moser yoke is really a 3R - you will have to try and see.
