Eaton H.D. Posi Limitations
Old 05-02-2004, 04:35 PM
99.9percenter's Avatar
Default Eaton H.D. Posi Limitations
At what point does this become marginal? M6, 4.10's
Old 05-03-2004, 01:51 AM
Spooln's Avatar
Default Eaton
I think the Eaton is a better posi unit then the stock torsen. I have seen the flut/planatary gears destroyed in a basically stock M6, the eaton unit has thicker/stronger planatary gears. Limitations i would say depends on what rpm you are dropping the clutch. M6s are very hard on the 7.5 GM rear, on an A4 the rear is more forgiven.
Old 05-03-2004, 07:08 PM
It is in a Strange 12 bolt.
Old 05-30-2004, 08:12 AM
Will it hold up for high 9 sec. runs?
Old 05-30-2004, 03:15 PM
plumbr's Avatar
Having problems with mine at 11.5 @ 120 on hoosiers
Old 05-30-2004, 09:50 PM
I will have to go spool, Then dana 60.......then dana 60 w/spool...
Old 06-01-2004, 11:18 AM
plumbr's Avatar
The dana 60 should solve any problems. With a spool it should be bullet proof. Good luck with the 9's.
