'99 Camaro Z28 M6 - Traction Control?
Old 08-28-2013, 01:08 PM
billscamaros's Avatar
Default '99 Camaro Z28 M6 - Traction Control?
I'm at 270K miles on my car and starting to hear whine from the rear end. My mechanic buddy suggests that I just swap out the entire rear vice rebuilding it. I've called around to a few junk yards and a couple have asked about traction control.
Do all Z28's come equipped with traction control? How would I know? There are not any interior switches to turn it off and on in my car.
Thanks
Bill
Old 08-28-2013, 01:12 PM
NicB's Avatar
not all cars came with it. if yours does not any 3channel rear end will work. tcs/asr is 4 channel rear ends
Old 08-28-2013, 04:40 PM
Is there a specific code that would appear on the door sticker? I see the "GU6" code that indicates the 3.42 rear gears.
Old 08-28-2013, 06:02 PM
FirstYrLS1Z's Avatar
I think NW9 is the option code for traction control.
3 channel ABS has a sensor on top of rearend.
4 channel ABS & TC has a sensor on each end of rear at brake backing plate.
Old 08-30-2013, 10:38 AM
2000ultraZ1911's Avatar
Do you have a button that says ASR? Does it fall on its face when you mash it with out turnin it off? Sounds like you don't I'd hope you know after 270k!!! Holy **** ur blessed longest last m6 ten bolt ever!!!!!!
Old 08-30-2013, 01:40 PM
Nope .... no ASR button. And I don't have the sensors at each rear wheel .... but I wanted to check to make sure.
I'm definitely not hard on the car. I'm a cruiser, not a racer. So 65 mph on the highway with a cup of coffee and some good tunes .... I'm content.
I've got 225K miles on my '01 Suburban.
Quick Reply: '99 Camaro Z28 M6 - Traction Control?
