If you have ABS/TCS (traction control) you can keep it with a 9" Otherwise you just disconnect your ABS if you want to run a 9" and dont have TCS. My ABS has been gone for a year and I dont miss it.
I took the cluster apart and blocked the little windows for the ABS inop and TCS lights with some black foam rubber. They use LEDs so you cant just pull the bulb but its simple enough to take it apart..
