need advice/ help change rear gear
Old 12-18-2013, 07:45 PM
Turnerd89's Avatar
Default need advice/ help change rear gear
So i have a 99 formula. and i just got a ta rear end out of a lt1 car with a 3.42 gear. im wondering what i need to do to get that gear out and in my rear end. or put my axles to the wheel on the old one.
In the long run, i need that gear to fit on my c6 zr1 5x120.65 rims. the adapters wont ever fit so i know the rims wont.
Old 12-18-2013, 10:45 PM
Z28Dave's Avatar
it might be easier to just swap the whole housing unless the the TA rear is shot.
Old 12-19-2013, 11:26 AM
Turnerd89's Avatar
sorry a bit of a newb to this platform. what do you mean by whole housing. I have to full rear ends, brakes and rotors and all.and need the 120.65 bolt patterns
Old 12-19-2013, 05:42 PM
Turnerd89's Avatar
bump someone please help
Old 12-19-2013, 06:20 PM
guppymech's Avatar
Turnerd89, You would get more help if you didn't use metric dimensions. 120.65mm=4.75 bolt circle. Check out this link from Mr. Shoebox about fitting late wheels on a earlier LT1 cars rearend.
http://shbox.com/1/4th_gen_tech2.html#wheel_mod
Old 12-19-2013, 09:41 PM
Turnerd89's Avatar
thank you for that. although I got some tools took the rotors off and found that out. the ls1 wheel adapter needs to be bored out a little bit.
Quick Reply: need advice/ help change rear gear
