need help/info on gear choice and stall choice
I'm building a 5.3l with a 76-80mm turbo running it threw a th400 and into a Moser 12 bolt with a spool. Building the car for 8th mile but will also see alot of street use ( NOT DD, dedicated street/ strip car) so I dont care about ride quality. I was told to go with a 4000 custom turbo stall and 3.5x gears but want others opinions. I wanna take full advantage of the turbo coming off of the trans brake.. All the guys around here are running nitrous and I wanna see nothing but Headlights in my mirrors..
We can do a billet front th400 converter in the LS bolt pattern so you can use the flexplate of your choice. I think our 258mm 3B would be a good choice for your needs. Fill out an ask Chris with some more specs and we can get you headed in the right direction. Link in sig
-Brian
-Brian
