T56-4l80e driveshaft change?
Old 05-12-2014, 12:52 PM
fly boy_1's Avatar
Default T56-4l80e driveshaft change?
I'm putting a 4l80e in a t56 car, will I need to get a new driveshaft? I'm not sure if the M6 shaft is longer than needed, if so I'll have it shortened, anybody know the answer?
Old 05-12-2014, 09:12 PM
Carl at CRP's Avatar
You will need a new trans slip yoke because of the spline count difference, then You can have Your driveshaft shortened to fit due to the 4L80 being 5/8" longer.
Carl
Old 05-12-2014, 10:02 PM
NorthTexasConverter's Avatar
Correct, and to add to what Carl said if you're making the swap I'd recommend investing a quality 1350 yoke, Strange is a good brand. Looks like Carl is a dealer for that as well
Quick Reply: T56-4l80e driveshaft change?
