Best 60 Foot on Stock 7.5"?
1.48, all stock with 3.42 gears, 4l80e.
I had a couple of 1.5 60's and then the 1.48 when I left on a little more boost off the line. Car weighed 3760, had all stock suspension except control arms, and made MANY 700-800 hp pulls. Didn't get noisy until the 1.48 60'. That was the end of the year last year. I didn't give it a chance this year since I put the 9" in right away.
Thanks! Added.
My best is a 1.70 60' . Stock rear end, 3.23, 3400 stall converter. I did add Moser axles and a Moser girdle this year just for fun. Hopefully it gets me by for awhile.
Yeah, knowing that you can run DR's down to 2.1(M6) or 1.7(A4) 60' without breaking it will help save some people time for when there S60/9"/8.8"/12 bolt is done, then they can hit it hard after.
#34
Added, Thanks!
Added, updated. Thanks.
#35
Best 60' is 1.50 clicking with back tires.
1.50 (A4, 3200 Stall, MT Radials LCAs, Adj TQ arm, Stock 10 bolt 3.23 gear no mods. over 200 passes.
The following users liked this post:
Jester95 (05-20-2024)
#36
My best is a crap 2.1. Only been out to the track once so I need seat time to get better at launching the car. Was doing clutch dumps varying rpm from 2500-3500 and the car would bog down hard and fall on it's face and then take off again. I don't know if it's maybe the tune or if I just need to slip the clutch or try launching at 4k+, but a 2.1 is where I'm at so far on Toyo TQ drag radials. Stock untouched rear with stock 3.42 gears.
