Need help choosing my rear end setup
I have a 9" shortened 3" per side. Its a housing an axle package with 35 spline axles. I need help deciding on everything else on the rear end that goes best with my setup.
Setup
6.0 with a 80mm turbo
4l80e transmission
I know its vague but any help is appreciated, I think a 3.50 gear will be the gear of choice for my car just unsure.
Chris
Setup
4l80e transmission
Chris
Plug your tire size and max rpm into the fbody gear calculator and see what it gives you and what you want. Kind of hard to guess without knowing how much power you're making and what size tire you are running.
