Clunk from the rear under hard acceleration
Old 11-02-2014, 11:16 PM
salvo's Avatar
Default Clunk from the rear under hard acceleration
Looking to get some pointers or guidance before I put the car in the air....
I have a 2001 trans am, m6, stock rear end with koni shocks, bmr springs, lca, lca relocation brackets, Panhard, and sway bar. I had the transmission rebuilt recently as well, and haven't put very many miles on it since then.
Under hard acceleration, standing or rolling, I will get a clunk from the rear end. Doesn't happen every time, but once is enough. Is there anything specific I should be looking? Thanks
Old 11-03-2014, 12:02 PM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Could be the U joint.
Old 11-12-2014, 10:18 PM
Majestic9C1's Avatar
torque arm bushing?? I had the same symptoms and it was my bushing..
Old 11-23-2014, 09:38 AM
deadcatsrule's Avatar
my 2000 WS6 trans am does the same thing ..with new u joints a umi torque arm with relocation kit.just installed a Founders Performance Lower Control Arms & Panhard Rod Kit today and still does the same thing .I'm thinking its the flow master exhaust is banging on the rear end
Old 12-03-2014, 04:54 AM
KCS
Moderator
KCS's Avatar
My car would do the same, ended up being a cracked factory torque arm.
Quick Reply: Clunk from the rear under hard acceleration
