clunck from the rear
Old 11-11-2014, 07:23 AM
06gtoLD's Avatar
Default clunck from the rear
Hey guys,
I have just under 53000 on the clock (06 gto). Never been to the drag strip but have had plenty of wheel hop from doing 40rolls over the years. I have noticed some whine coming from the rear about a month ago.I thought it was from taking out the rear seats, made sense to me.
Just last week I changed the trans fluid with napa dex 3 and rear diff fluid with lucas gear oil. Thought it was time for some up keep.
Now I have a big clunck from stop to first and a vibration when stop to first mid turn, like at an intersection. Is it my gears? Axles? Drive shaft? I figure its the dif bc it vibrates mid turn. I'd like to get your input before bringing it to a mechanic who might not no squat about my car but act like he nos everything and miss diagnosis it.
Old 11-11-2014, 07:40 AM
bgw70's Avatar
I am not sure about your '06 GTO but my '00 T/A called for posi additive when I changed the axle lube. I used the GM posi additive and Valvoline full synthetic 75w-90.
When I changed out the tranny fluid, I used valvoline Max life, which is good for all versions of Dex. So far, I have no issues.
Tranny Thread
Old 11-12-2014, 07:36 AM
06gtoLD's Avatar
@bgw70@
You are the man.thank you so much. I added the additive , drive around and it is completely gone now. big thank you.
Old 11-12-2014, 01:09 PM
bgw70's Avatar
Originally Posted by 06gtoLD
@bgw70@
That is Great News!!! Glad to hear it was an easy fix...you are very welcome!
Old 11-15-2014, 02:40 AM
LS1nut346's Avatar
Wow, I had no idea that additive actually did anything! I heard it made the posi slip a little bit but never thought there would be a clunk without it.
Quick Reply: clunck from the rear
