10 bolt question
Old 11-30-2014, 10:52 AM
ridndirty1000's Avatar
Default 10 bolt question
I have a roller camaro, I am buying a rearend through strang but they need my backing plates. No big deal but The body shop needs my car in 2 weeks. My question is if I take my backing plates off my rear end and put the axles back in will it still be able to roll. I dont want them pushing the car and an axle come out. I would put the c clip back in.
Thanks
Old 11-30-2014, 11:13 AM
FirstYrLS1Z's Avatar
C-clips will hold the axles in as a roller,backing plates are only for the brakes.
Old 11-30-2014, 12:01 PM
Ok Thank you I just didnt know if the backing plates made the axle sit properly in the housing or not.... I appreciate the answer thank you!
Old 11-30-2014, 01:10 PM
the bearing that is pressed in the housing end provides that support.
Old 12-01-2014, 11:09 AM
01ssreda4's Avatar
This is correct!
Quick Reply: 10 bolt question
