Can you comment on this pattern?
First rear build, ford 9" - input is greatly appreciated.
Summit Racing case (PEM), motive 3.70, aluminum pinion support, Yukon/Timken bearing kit.
This is backlash at 9-10 thou
One shim under pinion support, which is I am guessing .015-.020 (digital calipers battery died).
Can this be run safely? if not any ideas which way to go?
