help me diagnose differential noise please!
Old 01-24-2015, 10:39 AM
lmt0705's Avatar
Default help me diagnose differential noise please!
This is for my sons 02 Camaro. While driving the car there's a moaning noise that sounds almost identical to a wheel bearing noise. I completely disassembled it and found pitting on the carrier bearings. I replaced those along with the axle bearings and I replaced both pinion bearings while I was there. Backlash was a little sloppy till I replaced the carrier bearings but now it's right at. 008. Ring and pinion look to be in good condition but it's still making the same noise! Is the differential itself making noise? (I thought you would only hear that going around turns though)
Old 01-24-2015, 03:04 PM
FirstYrLS1Z's Avatar
LS1Tech 20 Year Member
Since you replaced the axle bearings,how were the surfaces on the axles where the bearings ride ?
Old 01-26-2015, 08:23 PM
lmt0705's Avatar
they were worn so i used the repair bearings that run on a fresh axle surface
Old 01-27-2015, 07:34 AM
01ssreda4's Avatar
Those repair bearings have a bad reputation. Is this car an m6? Every ten bolt, even low mileage units, that lived behind a manual transmission have pitted carrier bearings on the drivers side, and most did not make noise. As you can see by you replacing them they were not the source of your noise. Have you tried swapping wheels from front to back, and checking other suspension components while under the car?
Old 01-27-2015, 12:07 PM
Surprised that a member,that's been a member since 2006 and has 1034 posts,didn't search/research 'axle saver bearings' before acquiring/using them.
Quick Reply: help me diagnose differential noise please!
