12 Bolt Setup. Trouble Reading Gears.
#41
Crush sleeves when you get close you have to move very very very slow when you get close . I have started using solid bushing now when I do a gear set . It has the shims so you can set preload and just torque the nut down . I have come to like that method better .
If you already have the crush sleeve just use it . If you have problems you may want to consider the solid bushing .
The only way for a crush sleeve is by hand with a cheater bar . If it is under the car on jack stands I use a piece of angle attached to 2 of the u join mounts with a v notch so the socket will fit and bungee it up to the bottom of the vehicle so it will push up on the bottom . Then I use a 1/2" breaker bar and push with my foot . No way you will do it by hand under the vehicle . Don't be surprised how hard it will be to move it . Just take your time . Hope this helps and good luck .
#42
The spacer almost looks like a crush sleeve but does not have the crush in the center . About 3/16 to 1/8 thick .The spacer will come with some shims so you can fine tune the preload . Without shims it will be a little more of a task to get it the proper length if just trimming it but not impossible . Take a look st summit . I am sure there are some pictures .
Also I do know there is a truck spacer and one for a car for a 12 bolt .
#43
#44
Good deal , Sounds like you took your time and did thinks like you should . Doing a rear there is more to it than turning a wrench . You have to be patient and take your time .
#45
