Vent tube location for a 8.8/fbody housing?
Old 02-14-2017, 01:55 PM
Ernie W's Avatar
Default Vent tube location for a 8.8/fbody housing?
I'm nearing completion of my 8.8 build and completely forgot about the vent tube. I know most are in the axle tube but could I put it somewhere else? Where the tubes are stepped down it would be well over 1/2" thick, I could drill it no problem but just wanted to see where most others out there vent tube at. I still have the hole where the 3 channel abs sensor went in the 8.8 housing.
Old 02-14-2017, 04:23 PM
FirstYrLS1Z's Avatar
outside of the 'splash' area which is between the carrier bearings. Pic shows the OEM vent tube location port/hole. The OEM plastic vent fitting that is pressed in there I remove,and since the hole is 7/16",I tap it for 1/4 NPT and run the hose onto and along the panhard bar.
Old 02-14-2017, 04:29 PM
hiltsy855's Avatar
I put mine on top of the driver's side axle tube.
Old 02-15-2017, 06:56 PM
Ernie W's Avatar
Thanks guys. I ordered a new vent from Ford meant for the 8.8 axles and I'll just drill the tube and put it there.
Quick Reply: Vent tube location for a 8.8/fbody housing?
