overgearing and undergearing
You should go with a much taller gear then a 3.42 in your M6. No lower then a 4.10. If i had a 6 speed I would have a 4.56. I would also wait until you have the money to buy a 12 bolt / 9" and get the gears then.
Originally Posted by WS6FirebirdTA00
ok so i wanna go with a cam somewhere around 230/235 .580-.590 i have a 6speed car. are the 3.42's ok or should i go with some 3.73's?
If you are going to get serious about running car on strip, I would get a 9 inch or even a 60 for it but if it will be mostly a cruiser with a occaisional run at the strip a 3.73 in current axle would be a good compromise.
im just worried about getting bucking from the cam with that low gear ratio in there. i might go with a different rear end eventually but im not sure.
That cam will be easier to live with with a 3.73 installed than with a 3.42 and still keep it a good cruiser (if you want to keep it that way) and a good overall compromise.
