TA cover fluid checking technique
What is the proper rear diff. fluid level checking technique with the TA cover. I'm not sure if you use the fill hole in the TA cover for checking the fluid level or still use the factory checking location.
When I bought my rear it already had a TA cover installed so I used the instructions at http://www.installuniversity.com/ins...id_install.htm
