rear end help 10 bolt
ok, i know this is old but i would like some final advice.....
my motor rebuild is almost done and i would like to know if a set of dr'z in the rear is a bad idea? I know the stock is prone to but i curious. well, asking never hurt if the end result is about $2500.
so, wat do you think?
1. stock 10 bolt wth dr'z (nitto'z, toyo RA-1, or BFG)
2. stock 10 bolt with BFG'z KDW'z or kumho ecsta
of course, i plan on getting a harder girdle, and a set of LCA with brackets.
any suggestions?
any suggestions?
Broke mine on the 2nd pass with worn out BFG drag radials (255/50 16's). This was with 340-350 rwhp and about a 2500-3000 launch with a Mcleod twin. It was not side stepped as mentioned by some, but was let out quickly with the throttle mashed at the same time.
