9" questions
9" questions
I've gotten the price and company i want to assemble the 9" unit for my car.. but they don't offer abs or tcs provisions... for the assembly. if i get a TCS module and pull the fuse out of the ABS will that work?
Yep, that'll do it. You may as well go ahead and pull them both from under the hood as well. That'll remove a little weight. It's 8-9lbs for the ABS module plus all the wiring, and 2-3 for the TCS module and extra cable. Just get an ABS delete block. If you have a mill, you can make your own. It's a pretty simple task.
