12 bolt first drive - pulling hard to the left
I just installed my Strange 12 bolt and the car is pulling hard to the left. Can an incorrect thrust or pinion angle cause the car to pull?
LS1Tech Sponsor
Agreed. Check roll out. I would also check rear alignment of housing to chassis. It could also be an effect of a pan-hard being too long or too short, if the chassis' ride height has been changed from stock.
Originally Posted by 1BAD86Z28
Does it have a spool in it? Also check out your roll out of both right and left rear tires.
I got under the car to double check everything and found the torque arm had come loose. I fixed this up and took her for another spin and it feels great now.
Thanks for the help
LS1Tech Sponsor
Help a newB - can you tell me what you mean by "roll out"?
Thanks for the help
Thanks for the help
