anyone in here with 3.73 gears?
Old 03-28-2005, 08:25 AM
texada's Avatar
Default anyone in here with 3.73 gears?
I have heard that these gears are good from a dead stop. How are they from a rolling start and on top end?
Old 03-28-2005, 10:29 AM
MeanWS6's Avatar
assuming u have a 4L60e, they ROCK from a roll and up to about 100mph, after that u lose some top end
Old 03-28-2005, 11:22 AM
flyinZ's Avatar
I have had them for a few years...From a stop, your more liable to blaze the tires, but from a roll, you still might,lol...Just depends on mods.
Old 03-28-2005, 01:33 PM
texada's Avatar
Anyone else???? I would assume the 3.73's should pull pretty good in OD on top end Right?
Old 03-28-2005, 02:10 PM
SteveC's Avatar
Location: Poway, Ca. where GOD and the sun always shines
Smile
If you "blaze" the tires, you need a suspension beefup.
I have an 01 Z28 with a Y3000 2.0 STR, coupled to 3.73:1 rearend gears. My entire rear suspension has been replaced with BMR components, with SLP subframe connectors. From a dead stop, if I floor it, I will screech the tires, and then go from Farfetnugen to Fukenmovin.
With just 3.73's (before the converter) with the above stated suspenion, I would just get a light chirp.
You are only turning + 500 RPM from the stock 3.23.
SteveC
Old 03-28-2005, 06:48 PM
MNR-0's Avatar
Thats actually top advice SteveC. I run a stock converter and 3.73 and from a dig with no stalling I can launch fine - just holds on. Stall it and, well, as SteveC said, I need a drag setup.
I think you and I have a very similar setup SteveC. When I get my custom 3000/2.0STR converter my wheelspin issues from a dig might become a little more promounced.
Old 03-28-2005, 08:03 PM
nikon1999's Avatar
i had 2.73's before my 3.73's and my buddies mustang would beat me on the highway. With the 3.73's i just slowly put it to the floor in OD and smoke him The car just pulls from stop to top end, no matter what speed.
Old 03-28-2005, 08:18 PM
ULTIMATEORANGESS's Avatar
i noticed more pull in every RPM range after i had 3.73s installed.
Old 03-28-2005, 10:26 PM
2000TARiceKilla's Avatar
I had trouble hooking on street tires, so I went with 3.42's, better top end, semi better gas mileage, and got a stall in it. Also I'm able to use nitrous in 2nd gear longer, and all the way through 3rd, so all in all my cars actually faster with them in. And quiet, thank god.
Old 03-30-2005, 04:15 PM
Quickin's Avatar
I can roast my BFG drag radials on the street from a stop, I let off after about 200 yards one day. From a roll at about 40mph they will still break free if they're at street pressure. I have to be at about 55mph to get traction is I mash it to the floor. Top end...it pulls like a bitch until 150mph.
Old 03-30-2005, 08:35 PM
flyinZ's Avatar
SteveC
Its not a matter of suspension, b/c thats all done..It needs some sticky rubber, that'll help the most. At least for me, anyway.
Old 03-30-2005, 09:04 PM
DOUBT IT's Avatar
I have the Precision 3.73's. I love them. Definitely a difference over the stock 3.23's. I used to only light my street tires up in first, then had a slight chirp into second. With the gears, headers, TD's, and and a tune, I can absolutely incinerate street tires in 1st, 2nd, and chirp 3rd sometimes. I have Nittos DRs on there now, and even with them warm, I can spin 1st and peel out going into 2nd pretty good.
From a roll, I noticed a big difference in how the car pulls. I used to have people get the jump on me and then have to reel them in, now I jump out in front and steadily pull away from most cars that're a close match to mine. I did notice that it doesn't seem to pull quite as hard above 120 as the 3.23's but most of my races are over by then.
Old 03-30-2005, 11:49 PM
00firebird's Avatar
thats how all higher gears should work until they reach their ends which is like, theoretically 170 or something ludacrious. I dont get why people think gears get slow at the top
Old 03-31-2005, 12:18 AM
john shea's Avatar
I love my 3.73's .Look at sig not bad!
Old 03-31-2005, 02:10 AM
hepcatws6's Avatar
I have 4.10's, and yes they are great on the take off...
Old 03-31-2005, 08:31 AM
99SilverZ's Avatar
I've been looking to buy 3.73's and I see a lot of good things with that gear. What are the cons about the gear?
Old 03-31-2005, 12:07 PM
00firebird's Avatar
from what i've heard, not much. maybe youl lose a mpg of gas if u do alot of highway. some ppl say they get better mpg in the city.
Old 04-01-2005, 08:51 AM
99SilverZ's Avatar
That's good. I'm shopping for one now. Any suggestions?
Old 04-01-2005, 05:11 PM
DOUBT IT's Avatar
I love my Precisions. They only whine when you let off the throttle and let it coast, or if you're BARELY on the throttle.
I've heard that the Motives are good too, really the most important thing is to find someone who knows how to set them up properly. I had a guy do it locally who has done literally hundreds of Camaro gear swaps.
Old 04-01-2005, 07:38 PM
FastLS1Chick's Avatar
Well I have 3.73 and they pull 120mph in the 1/4 and used a gps to check top speed let out at 152mph I got scared. I love my 3.73 great for street and strip racing.
Quick Reply: anyone in here with 3.73 gears?
