pros and cons moser 9inch vs 12bolt
Old 04-10-2005, 11:32 AM
TXZ28LS1's Avatar
Default pros and cons moser 9inch vs 12bolt
what are the pros and cons. obviously our 10 bolt sucks, so anything better will do. hows ther performance for these 2 different rear ends. i figure going with the 9inch is alot cheaper?
Old 04-15-2005, 12:44 PM
insaneclown's Avatar
Do a CarCraft search on this. They had an article on it and you can see it online.
Old 04-17-2005, 08:01 PM
Hardtop00SS's Avatar
I would have gone with a 9" rather then the 12 bolt, but I am happy with the 12 bolt. I think the 9" will be a little more expensive, but I may be wrong....
Old 04-19-2005, 03:27 PM
Hawkcmc's Avatar
Between the 2 I would choose a 9" hands down the peice of mind is WELL worth it and if you decide to every change gears beleive me you will be happy you got a 9".
CMC
Old 04-19-2005, 04:13 PM
ynneK's Avatar
although I've seen some intresting work post here to get 3 channel ABS working with the 9", its not really possible.. If you have the 4 channel ABS, or don't care about it, then this isn't an issue.
Old 04-19-2005, 11:32 PM
01SLPSS's Avatar
LOve my 12-bolt but can't change gears like 9" but Torque arm mount on 9" is Pain in the A$$!!!!!!
Old 04-20-2005, 08:26 AM
Hawkcmc's Avatar
Just ditch the ABS if you are a 3 channel and take the bulb out of the dash if it bothers you. You can barely even tell the difference.
Chris Caprio
Old 04-20-2005, 09:48 AM
Blue Hawk's Avatar
12 bolts : Less drivetrain loss. 3-channel availability.
9 inch. : Stonger (especially in M6 applications). Easier gear swap.
I wanted a 9 inch but ended with a 12 bolts because I have a 3-channel setup and I wanted to keep my ABS (daily driver). So far, my 12 bolts worked fine with minimal gear whine. Used to be totally silent until I started to get on it
