Which yoke do I have?
I bought my rearend used and my driveshaft used from someone else. I was told both are 1350's. Problem is the rearend original owner has never ever been back online to check mail. When I bolted the driveshaft up to the rear, it fits, but doesn't look exactly right. Is there a sure shot way to identify my rear end yoke or should I take it to a shop? The DS definately is a 1350 and looks bigger to me than the rear end. Keep in mind, it DID bolt together, but I will launching at 5k+ with over 400 rwhp.
Here si what Derty told me:
Originally Posted by DERTY
A 1350 U-Joint will have caps that are 1-3/16" in diameter and are 3-5/8 across the flat part of the caps. 1310 U-Joints are 1-1/16" in diameter and 3-7/32 distance across. There are also cross over U-Joints that are 1310 on one side and 1350 on the other
