Rear End Leak
Old 05-16-2005, 05:27 PM
oodahss's Avatar
Default Rear End Leak
My past two camaros have had juicy rear ends from day one pretty much. Is this normal for our cars or do i just have bad luck. They don't leak bad they are just juicy all the time. Should I be worried or is it ok??
Old 05-16-2005, 05:35 PM
SScam68's Avatar
Where is it leaking from?
If you run a search you'll see that the pinion seals are very poor in these vehicles.
I had to replace my pinion seal and a carrier bearing this weekend. My friend suffered from the same "leaky" differential. He's replaced the seal on his 3 times already.
Old 05-16-2005, 05:37 PM
oodahss's Avatar
thats where its comin from
Old 05-16-2005, 09:06 PM
LS1Tech Sponsor
Scott@DrivelineSolutions's Avatar
LS1's and 10 bolts don't mix.
Old 05-16-2005, 09:18 PM
joepizi's Avatar
I had the same problem on my firebird, I had to have the seal replaced, but I ran at least 5000 miles before I had it replaced and had no problems.
Old 05-17-2005, 08:47 AM
oodahss's Avatar
I figure as long as its full and not leakin to bad i'll be alright for a while
