identifying Gears?
Old 06-26-2005, 08:01 PM
fattdaddyLS1's Avatar
Default identifying Gears?
I forgot to look at the rear end gear code on the tran am my 10 bolt came out of so I'm tring to find out what gear it has any ideas!
Old 06-26-2005, 09:30 PM
Tally TransAm's Avatar
im guessing its outta the car, if so easy way
spin pinion over and count the times you spin the pinion over to get the alxe to spin over 10 times.
divide the number you spun the pinion over by ten and that is your gear ratio
or if your lazy like me
count the number of pinion spins to rotate the axle once. this way is quicker, but you have to guess a little. (ex. if it looks like the pinion spun 3.5 times to get one axle spin, you probably have 3.42's)
Old 06-26-2005, 09:46 PM
Well I'm almost sure it is 2.73, my next ? is should I leave it because I'm going with a 3200+ stall on a 400+ RWHP car or should I spend the money for the carrier gears and swap!
Old 06-26-2005, 10:02 PM
BTW I don't have the money right now to buy a 12 bolt!
Old 06-26-2005, 10:15 PM
i would go 3.42-3.73
Old 07-03-2005, 08:11 PM
I saw in one of the part mags that you can just buy bigger gears for the 2 seris carrier they are a little more money, is this true? and if so what else do I need!
