Driveshaft length???
when i installed my 12 bolt i had to cut an inch off the stock langth of the shaft
the only reason i had to do this is because i had the "billit" 1350 yoke on the rear. if you get the regular 1350 or 1310 yoke you dont have to cut the ds.
when i searched this was the info i cam up with and when i did my rear it was exactly what i had to do
Jeff
Jeff,
You're best bet is to talk to your driveline manufacturer and see how they require the measurements.
For example, Denny's uses this procedure: http://www.dennysdriveshaft.com/html/how_to_measure.htm
In my case I used template B ( http://www.dennysdriveshaft.com/html/b.html ) when ordering my Denny's and came up with a length of 44" with MN6, Strange 12-bolt w/1350 yoke, and car lowered about 1.5". This turned out to be the exact same length as the stock driveshaft:
