Motives thick vs normal gears???
Restricted User
Are the thick gears worth the extra $120 +/- or what? Wanting to step up to 3.73 or 4.10's but not sure if the thick should get the extra money?
Charlie
Charlie
Originally Posted by CAT3
Wow, thought someone would have had input on this one for sure.
I was confused until yesterday on this point, so you're not alone.
Originally Posted by HotRodNeil
Be careful in that "thick" gears usually mean that you can put them in a series 2 instead of a series 3, as they are thicker only on the shaft, which means you don't need an adapter. The teeth are not thicker, so don't be confused, as they're not any stronger.
