Can I put a 10 bolt w/4 channel in a car w/3 channel?
Time to finally get a 12 bolt for the 01 SS, the rearend is going out in my 98 so I wanted to know how could I do put my 10 bolt in my 98 SS?
My 01 SS has ABS/TC which is 4 channel and my 98 SS doesnt have TC so its 3 channel right? What needs to be done to my ABS/TC 4 channel 10 bolt to go in my 98?
thanks
thanks
you can swap them. put the four channel in the 98 with the 3 channel axel's. you abs sensor will not work though and tere's no way to convert the four channel system to three that I know of.you could use the four channel axel's but the have gear drives on the end for abs sensors that you won't need. I currently just blow a four channel rear in my car that doesn't have tc. smoke show's and 10bolt's aren't good combanations.
